Results 1 to 1 of 1
Thread: Frictional wear resistance of Carbon-Fiber tube. (Question)
    Jan 2011
    I am wondering if anyone can help me out with a question I have. I am wondering how Carbon-Fiber tubing holds up against frictional wear. Specifically, a CF tube with an ID of 7.00MM and the material passing through the tube would be a 6.95MM Styrene bearing travelling at roughly 400FPS. The weight of the bearing would be around 0.39 Grams.
    I have used brass tubing in the past for a base testing result, and the wear on the inner surface of the tubing was acceptable up to about 7000 bearings. Basically I am wondering if the CF tubing will be more or less resistant than the Brass.
    The tubing material info is as follows:
    -Material is standard modulus (17 MSI) uni-directional carbon fiber pre-preg
    -resin/fiber ratio of 33:67
    I am open to any suggestions you guys/gals might have to offer me. I am also wondering if their is a product you would recommend that I could coat the inner surface of the tubing with to increase the wear resistance while still maintaining the required tolerance.
    Thanks for your time and advice.
  1. Tools for machining solid carbon (not carbon fiber)-more posted
    By camcutter in forum Composites, Exotic Metals etc
    Last Post: 04-27-2007, 07:23 PM
  2. Carbon Fiber
    By DrasticSports in forum Employment Opportunity
    Last Post: 03-29-2006, 06:19 PM
  3. Carbon fiber
    By turmite in forum Composites, Exotic Metals etc
    Last Post: 08-03-2005, 11:20 AM
  4. Carbon fiber
    By CNC Pro in forum CNCzone Club House
    Last Post: 03-13-2004, 05:32 AM
  5. carbon fiber
    By teilhardo in forum CNCzone Club House
    Last Post: 03-05-2004, 05:40 PM
