The local metal expert here says don't even consider the 6065. Way to soft and ductile for something like this. The 7076 has strength similar to steel so it might work. He recommended you sleeve it with steel though. Also he said why bother when the housing is cast iron. Your going to save maybe five pounds max. why not just go with 4140 and open it up a bit more.
LinkBack URL
About LinkBacks
