Results 1 to 2 of 2
Thread: stepper motor help
    Jul 2010
    stepper motor help
    HI
    I didnt know where to put this question,
    i have a big roller laminator that i would like to attach a motor to, i was looking at the nema 34 & 42 motors, is it possible to run them without a controller board? just be able to plug it into the wall socket somehow and have a switch for forward/stop/reverse? or perhaps be able to put a variable speed dial on it to speed it up and down? has anyone made something similar or can point me to a website, thanks for your help in advance
    Chris
    Feb 2009
    Nobody seems to have chimed in on this so let me see if I can answer your question. I am a bit of a newbie myself so don't take this as gospel but I believe I'm right. The short answer is no this won't work. Stepper motors require some sort of controller to operate. What I would suggest is that you find a winch motor and adapt it. I don't know if they have Harbor Freight in Australia but they have a deal right now four 44 bucks here in US for an electric trolley. It comes with a gear drive 1/2 horsepower motor that just plugs into the wall and has a push button rocker switch for turning forward or backward. something like this could probably be adapted fairly easily.
    Good luck and hope this helps.
  1. Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 06:50 AM
  2. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors and Drives
    Last Post: 07-25-2010, 03:19 AM
  3. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum Product and Manufacturer Announcements
    Last Post: 06-07-2010, 04:59 AM
  4. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors and Drives
    Last Post: 10-16-2007, 05:56 PM
  5. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors and Drives
    Last Post: 01-03-2005, 06:05 PM
