Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
  #13
Old 07-27-2005, 08:38 PM
Gold Member
rboeser is on a distinguished road
Here is one German site I have bookmarked.
http://testduits.sb-microstep.com/Wi...eutschland.htm
Old 07-27-2005, 09:09 PM
Moderator
Halfnutz is on a distinguished road
I have a Hobbycnc package running a 1M X .65M table router and it works well. It has adequate power. The kit was very easy to build and I would highly reccomend it for a beginer. I learned a lot with the kit, and have no regrets, it was an excellent investment. I think it would be enough power for your router, from what I can tell by your pictures. You could easily find a transformer with a 220 volt input and a similar output, and everything else should work fine as is.
Congratulations on your start, it looks great, and welcome to our mottley crew!
Halfnutz
  #15   Ban this user!
Old 07-28-2005, 03:52 AM
hansa is on a distinguished road
Cant make the shop on the dutch page work
Halfnutz! What package did you go from? and where can i read about it?
Do this Forum have a IRC channel or something? for realtime problem solving
Old 07-28-2005, 08:59 AM
Moderator
I got a kit from HobbyCNC with a three axis board and three 200 oz/in stepper motors, and then I had to buy the transformer and case, and solder the board together. You would just need a 220V transformer and case, the rest of the stuff is in the kit from HobbyCNC. It was cheap too, only a couple hundred bucks for everything. Just do a search for HobbyCNC.com and you'l see everything there under the three axis package.
We have a chat room but people only use it for a few minutes in the evening.
Halfnutz
  #17   Ban this user!
Old 08-02-2005, 03:57 PM
OK. Now if found my self some rollerblade ballbearings and iv drilled a hole in my treadet rod :P hoho! progress! I still have'nt desided on a kit thow. IM afraid ill go for the 200oz kit even thow im afraid its a bit on the weak side..
the table will be 92x96cm
  #18   Ban this user!
Old 08-04-2005, 06:04 AM
And the frame is bought :P it ended up on 92x92cm. Ill post some pics at weekend. Ill make a worklog at my webpage for those interested to
