Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 07-25-2005, 12:45 PM
Chris D's Avatar
Chris D is on a distinguished road
Mechanics question - force at end of screw...
I am working on a new tool holder system for my bench top lathe. I am trying to get a handle on how much clamping force I need for the tool blocks. Currently, the tool bits are held in the block with three 1/4-20 set screws, so that is going to be my baseline.
I am wondering if someone can tell me how much force is applied to the tool bit using one 1/4-20 setscrew with a 4" long allen wrench.
If you have the formula, I would appreciate a walk through on it too so I don't have to bug everyone again as the design progresses.
Thanks!
Chris
Old 07-25-2005, 12:48 PM
Chris D's Avatar
I guess it would also be helpful if I knew how much force is being applied to the 4" long allen wrench - frankly I don't know. I have not used that small of a torque wrench in many years, so I am not even sure of that anymore - it sucks getting old.
Let's guess at the force being 15 pounds as in 15 pound feet of torque if that seems reasonable.
CHris
Old 07-25-2005, 08:49 PM
OCNC is on a distinguished road
Thanks!
Chris
Check out this link or this one for a bolt torque calculator. Google bolt torque calculator for other hits.
Old 07-25-2005, 09:00 PM
ViperTX is on a distinguished road
Just looking at the Machinery & Metalworking hanbook....
T = KLD where T = Tightening torque in lb-in,
K = dynamic coefficient of friction (0.15 if dry and zinc plated)
L= clamp load, lb
D= nominal bolt diameter, in.
So, what you're looking for is the L (clamp load).
Paul
Old 07-25-2005, 09:30 PM
fyffe555 is on a distinguished road
L= clamp load, lb
Paul
It's surprising the thread pitch isn't a factor..
Old 07-25-2005, 10:56 PM
A more comprehensive formula and explanation that includes pitch can be found here . Also check out boltscience.com.
Old 07-25-2005, 11:42 PM
Actually L = Minimum Yield Strength of the Bolt x Stress Area of bolt
The stress area of the bolt is based on it's thread and the Min. Yield Strength is based on the bolts grade.
What OCNC refers to is the basic equation...what the Machinery Handbook does is work with an equation and Tables.
Old 07-26-2005, 08:09 AM
Chris D's Avatar
Thanks guys!
Much appreciated.
Chris
