your intermediate 30 tooth gear is just an idler gear as you have it... you need another smaller gear on a common shaft as the 30 tooth gear for reduction
if you are looking for more reduction then connect another 19 tooth gear to the same shaft as the 30 tooth and drive the 38 with that...
ex. stepper-19>>30(connecting shaft)19>>38-output
LinkBack URL
About LinkBacks
