Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-24-2005, 05:52 PM
Goldhunter_2 is on a distinguished road
what type of CNC do I need?
ok lets reword my question maybe I am over looking something I cut metal
16ga steel
.90, .100, .125 sheet alum 5086
1/8, 1/4 alum tube, bars etc...
would also like to make props and gears in alum three pistion cutting unit. andcould build smaller unit for these to test before building 8'x20' unit to handle sheets. in my earlier post diguy said somthing about plamsa and use of old printer parts I had orginal thought waterjet and i see alot about routers on here. so the big question is what kind of CNC do I need to look at? please the cheaper the better!!
Old 06-24-2005, 09:28 PM
ger21's Avatar
Waterjet would cost you $100,000 minimum. You can't cut steel with a router. For the sheet materials, I'd say plasma would be the cheapest way to go. SOunds like you really need more than 1 machine, to do everything you want.
Old 06-24-2005, 09:41 PM
well I may need more then one but they take up space I don't have to spare for the smaller thicker parts like gears and props I could try a plasma and that would give me a idea. at least that would be a place to start, the tables seem simple not sure how to build the plasma cutter other then buy one and attach it
any ideas where to look at drawngs for building a plasma CNC unit? also stll like the see diagrams of the waterjet pump system if you run across any
Old 06-24-2005, 10:35 PM
Gold Member
Ken_Shea is on a distinguished road
Goldhunter_2,
You may want to re-think on the plasma, I am not knocking them or saying that they will not do what you require, they have there place just like every other form of material cutting, however, from what I know of them, they are not designed for close tolerance or surface finish critical parts, they can be finicky and warpage is a factor.
Ken
EDIT:
So I don't get taken to the carpet
There are precision plasma cutters, but you are not going to build one in the garage
Old 06-24-2005, 11:29 PM
ok ken you talk bad about my build capabilities
My first choice was a waterjet but they don't seem to be popular in the home built section Plama would be ok for the sheet stuff not sure how it would would on gears and props tell I try one .
Is there anyone down here is Port saint Lucie fl with a home build cnc machine I can actaul look at
Old 06-24-2005, 11:47 PM
Gold Member
Is there anyone down here is Port saint Lucie fl with a home build CNC machine I can actaul look at
I know what you mean, pictures are wonderful but they can't compare to actually looking at one.
I have a nephew in Port St Lucie, but he is not into CNC.
Mike Waldman, you by chance know him, he is into dyno'ing motorcycles.
Old 06-24-2005, 11:57 PM
no sorry don't know him ya I have always done better building something after seeing up close
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 01:06 AM
Making money with CNC Johnuk CNCzone Club House 26 12-13-2009 11:46 AM
Fanuc CNC controler zekk_2 Servo Motors and Drives 19 02-27-2008 02:46 AM
Panel Saw type CNC? Edh DIY-CNC Router Table Machines 11 05-30-2005 10:05 AM
The start of a big CNC project... UKRobotics General Metal Working Machines 10 09-30-2004 06:34 PM
