Why not just use electrical PVC conduit ( gray) and use it and the different fittings that are available? A large diameter should give you sufficient strength. A long piece installed vertically and braced via a T or 2 also attached to the tower, would be inexpensive, easy to build and readily available materials. You might even be able to foam fill and cap the end for more rigidity if needed. Just a thought.
LinkBack URL
About LinkBacks
