| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Im curious to know why a heavy iron base it vitial for a sturdy machine? Is it possible to make a machine that will cut largish parts within an accuracy of 0.0001" that is constucted of a steel/aluminium frame? Whats the advantages of a heavy frame if any? |
| Rigidity.Anyone who has tried converting a drill to a small mill will tell you. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Resonance frequency. The larger the mass, the less likely the machine will resonate, or vibrate. Aluminum, even in bulk, will still resonate - it's kind of like a rigid spring. Iron doesn't like to vibrate, aluminum does. Vibrations create chatter which can start one heck of a destructive cycle. It's not 100% dependent on the material, though. Shape has a substantial impact on resonance. The use of iron is a safety factor to make shure you don't build an expensive, automated tuning fork. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| FWIW, It is possible to design a machine with a steel weldament and fill with concrete. The concrete provides mass and vibration damping. I've seen it done a a HUGE scale custom machine. Built in place, it will never be moved. Karl |
| [QUOTE=Com] Is it possible to make a machine that will cut largish parts within an accuracy of 0.0001" QUOTE] Anything is possible (so I am told). But IMO it is VERY EXTREMELY UNLIKELY. That's why you pay over a million for the big accurate machines.
| Concrete is a good dampener, for sure. Low shrink grout is excellent for this kind of thing. If you do it, use a fairly dry mix and compact it with a vibratory settler to remove the air - you can rent one pretty cheap. Intimate contact between the steel and the grout after the grout is cured is essential for best results. It is a good idea to at least clean the surfaces that will contact the cement or grout and if possible, prime. Don't fill when the structure is cold - warm it up and let it 'soak' first. Get the filler material and the structure at about the same temp and keep them there to avoid internal condensation. Scott
In the late 70's & early 80's the Japanese had some machines at the National Machine Shows and the frames were pre-stressed concrete. Other than this, I have no idea as to how they worked. I know that these units were advertised as being accurate to 0.00001 inch. Jerry |
| "Interesting" stuff them foreign folks come up with, huh? .2 micron tolerance? Wow. That's ....uhm....pretty good. Scott
#10
| That is nuts, there are to many external factors to really get a large machine to have a .00001 accuracy, Now resolution is possible but accuracy, the thermal characteristics of the room, the floor isolation the load, the application of power and the friction of the system will cause more inaccuracy than that. Most gage block are only certified to around that. I work in a dimensional metrology lab that was one step from NIST in the certification chain from about 1983 -1988. I do know what I am talking about. We had samll single axis micrometers that would do about 0.00001 accuracy on a good day. |
#11
| The Japanese are famous for ignoring reality! I'm an engineer at Mitsubishi, so this is not a slam - it's an observation. Very tight environmental controls are mandatory - all the way down to the way the site was prepared for the isolated foundation the machine would have to be set on. OH - CJL didn't say how big the machine was, DieDude - I almost jumped to the same conclusion since that is the topic of this thread ("largish parts") - that the machine CJL mentioned had to be a monster, but heck - the machine may have only been a couple of feet long - who knows. Either way, I agree than sub-micron machines are not commonplace, for sure. Scott
#12
| In my last big machine shop gig I did in the 80's and 90's we had some lathes made by Moore Machine that would actualy turn contour parts to about 0.00005 in. accuracy in about a 1 foot cube. They were on isolation foundations, in there own room with no operator and a precision air flow system much like raised floor computer rooms, used roller v ways, had air bearing spherical spindles, use laser for positional feedback and yaw correction, had 4th axis for the tool post so the cutting edge remained normal to the workpiece and used precision diamond tools. They literally cost millons way back then and were state of the art for there time. Guess what the physics ain't changed since then. |
| My First CNC Machine, Mr. Chips | Mr.Chips | DIY-CNC Router Table Machines | 81 | 02-10-2007 10:04 AM |
| How to decide if an old milling machine is good? | crazyman | Knee Vertical Mills | 15 | 05-01-2006 09:57 PM |
| They look like a good machine | cncman2 | Commercial CNC Wood Routers | 12 | 05-12-2005 01:37 PM |
| FeatureCAM Expands Product Offering with Machine Simulation | CNCadmin | Product Announcements & Manufacturer News | 0 | 01-21-2005 07:58 PM |
| Fruit Machine Stepper Motors - Any Good? | koslaz | Stepper Motors and Drives | 3 | 10-22-2004 03:45 PM |
