| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Hi all, I will be starting my CNC project real soon and at the moment I am in the designing and resourcing stage and have had an idea. I am building a JGRO style CNC and it will have a cutting envelope of 32"X18"X 3-4 inches. I was planning on using 1 inch gas pipe for the X axis then it dawned on me why not use 1 square tubing and surely this would have less flex? as there are 4 corners which technically should be more rigid, would I be thinking this would be correct or not. I will also be using the skate bearing and aluminum angle slides for this on all axis if it helps. Kammo1 |
| square tubing is more rigid than round in comparible sizes
__________________ IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| The start of something new ...I Hope... | bgolash | CNC Wood Router Project Log | 74 | 01-31-2010 08:50 PM |
| Bridgeport Series 1 Retrofitted! | biomed_eng | General Electronics Discussion | 9 | 08-24-2006 09:19 PM |
| Peck Tapping (Rigid) | Rekd | Haas Mills | 43 | 12-02-2005 06:51 AM |
| Can you make bearing pipes more rigid with pressure? | trilect | DIY-CNC Router Table Machines | 33 | 08-14-2005 12:56 AM |
| Rigid tapping on a BPT TC1G w DX32 control | machintek | Bridgeport and Hardinge Mills | 0 | 01-01-2005 08:06 PM |
