Results 1 to 2 of 2
Thread: Momentum formulas
    Registered sebastian_dogar's Avatar
    Mar 2010
    Romania
    Momentum formulas
    Does anyone know the formula of the torque momentum of a CNC lathe? I want to make a connection with the machining momentum and see how much I can change the machining parameters.
    Jun 2010
    Start off with the mass and rotational inertia of the head stock, spindle, and motor. If the part being machined is significantly heavy, >1/10 the mass of everything else rotating, add that it as well.
    Essentialy the combined inertia of everything that rotates. This will give how hard it is to accellerate / decellerate rotationally. Then multiply that by the diameter of the part being machined to see how much cutting force that relates to.
  1. book with formulas?
    By inthedark in forum Bending, Forging,Extrusion...
    Last Post: 10-07-2009, 01:52 PM
  2. Stepper Formulas
    By miniengine in forum Stepper Motors and Drives
    Last Post: 09-07-2009, 01:27 PM
  3. Problem using stepper for high-momentum load... (blowing drivers!)
    By Riceburner98 in forum Stepper Motors and Drives
    Last Post: 09-17-2008, 01:29 PM
  4. NEED HELP (NEED FORMULAS SPI &SPS)
    By bradyfb in forum CNC Wood Router Project Log
    Last Post: 06-05-2006, 09:27 PM
  5. Electronic formulas
    By turmite in forum Forum Questions or Problems
    Last Post: 12-08-2003, 01:51 AM
