Try looking for simple beam deflection with distributed load.
You have to calculate the moment of inertia (I) from the cross section of the plate and use the formula for a simply supported beam with the weight of the plate being your distributed load.
I can't give you any links to find the equation(s) but you should be able to find them through Google.
LinkBack URL
About LinkBacks
