Results 1 to 1 of 1
Thread: Moving motion transmition
    Aug 2008
    Algeria
    Hello,
    I need to feed a linear moving device with rotative force. Then i need your advice about such a system.
    I came up with the solution shown on the sketch, wich consists of a carved rail in a long rod or tube attached to a motor, and a gear sliding over the rod and hooked to the rail. The gear is connected to the moving device somehow with bearings to insure linear movement and connected to an other gear trought tooths side.
    But I'm not sure about the friction effect on both linear and circular motion (planing for less than 3000 rpm).
    Anyone have a better idea?
    Thanks.
    Attached Thumbnails Attached Thumbnails Moving motion transmition-bitmap.png
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 02:48 PM
  2. Moving Table, or Moving Gantry? (For Router)
    By Cryptonic26 in forum DIY CNC Router Table Machines
    Last Post: 04-20-2011, 03:38 AM
  3. Discussion of moving table vs moving gantry
    By rkremser in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 04:59 PM
  4. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-27-2007, 09:48 PM
  5. Moving gantry.....or moving stage
    By Cutloose in forum DIY CNC Router Table Machines
    Last Post: 10-16-2005, 01:53 PM
