Results 1 to 2 of 2
Thread: Changed over from 13 TPI to 2 Turns Per Inch, Help!
    May 2010
    Question Changed over from 13 TPI to 2 Turns Per Inch, Help!
    Using the book written by Patrick Hood-Daniel, I built my first machine. Was working fine up until the Z axis starting grinding. So I replaced the 13 TPI steel rod and nut with an ACME 10 TPI (5 start) and backlash nut. Rides very smoothly now, but I have no idea how to reconfigure Mach 3.
    I believed that I could just change the TPI number in the equation 200*13*4 where 13 is the TPI.
    However I've been told that it's not really that easy.
    Can anyone direct me to where I can find this info?
    Mar 2003
    Shelby Twp, MI....USA
    if using 1/4 microstepping, then yes, 200*2*4 = 3200
  1. Problem- Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Wood Working Tooling
    Last Post: 07-02-2009, 06:38 AM
  2. 4th axis turns to many turns
    By cob in forum Mastercam
    Last Post: 02-16-2009, 01:19 PM
  3. 1/2"-8 ACME 2 Start (4 turns per inch)
    By andy_ck87028 in forum Australia, New Zealand Club house
    Last Post: 04-03-2005, 10:44 PM
  4. Turns per inch to metric conversion
    By sixpence in forum DIY CNC Router Table Machines
    Last Post: 08-28-2004, 03:19 AM
  5. turns per inch vs threads per inch
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-18-2004, 10:27 AM
