Page 1 of 10 1234 ... LastLast
Results 1 to 12 of 120
Thread: Need some FEA of HEB beams for a mechmate like router
    Feb 2008
    earth
    Question Need some FEA of HEB beams for a mechmate like router
    Hi guys !
    Can anyone help with some FEA of HEB beams for a mechmate like router ? (sideways & torsional (moment) loads)
    I think about using two HEB 100 beams for the X axis & one for Y axis, the HEB beams are laid out like H rails, in the gap of the H will be a room for a roller chain drive system, & the H will get the loads form the sides(like if it was an IPE, i hope you understand what i mean)
    Well, HEB 100 is made of two 10mm thick vertical plates (the sides of the H) & one 6mm thick horizontal plate.
    Why HEB ? because HEB beams are cheap, available, relatively accurate & can act like rails & beams at the same time.
    Why FEA ? to know if it is possible to use the HEB as unsupported rails & beams at the same time & having a machine rigid enough & capable of 0.1mm accuracy minimum.
    The table will be 270cm X 150cm X 30cm, yes 270cm unsupported beams if possible, say the Z+Y gantry are around 120 Kg & feed force is around 170 Kg...How much will it flex ?
    Let me know if you need more info.
    Thanks !
    cnc2.
    May 2007
    Why FEA?
    These calculations are relatively easy for any 3rd-year mechanical or civil engineering student, by hand. That being said, you have more problems than (presumably) not knowing how to do these calculations.
    What support will the two X-axis beams have? Are they lying on a floor, supported only at the ends, supported with some kind of welded frame? If you expect calculations or finite element analysis to be predict better than 0.1mm, the information you feed in gets very important. Material properties, exact section properties, loading conditions, support conditions, etcetera, etcetera. The precision to which you know these properties will dictate the precision to which FEA can predict deflection.
    Apr 2007
    Hi, I looked into the material a bit more and changed my answer.
    HEB 100 is just 100mm depth. This might be sufficient for a 150cm distance, but not even close for the 270cm distance. For the 270cm distance, you will need more like 200 - 300mm depth. HEB 240 - 300 sort of range.
    The good news is that you have a starting point for the forces, so this can be used to in some simple testing. A laser pointer can help with the deflection measurements.
    Feb 2008
    earth
    Quote Originally Posted by wutzu View Post
    Thanks for the reply wutzu !
    Well, I'm a computer guy, so this kind of calculations are not in my knowledge base if i can say so, and I'm in the design stage of a cheap/easy to build router.
    The X axis beams are preferably supported(bolted) only at the ends (the simplest way to build it, if viable) The H beams are not used in their original intended way, they are laid on the side like an H not like an i. They are bolted at the ends on a preferably all bolted frame made out of some kind of IPE80 or tube, i'm not sure yet about the whole design, that's why I need to know if the starting point is ok.
    I've found a CM66 excel sheet for calculating steel beams but it calculates them like they are used in buildings which is not what I want. In buildings the H is used horizontally & I want to use it vertically.
    I hope you understand what I mean
    Thanks !
    cnc2.
    Feb 2008
    earth
    Quote Originally Posted by harryn View Post
    Thanks for the reply harryn !
    HEB300 ??? the half of the X axis will weight more than a whole mechmate
    Look at the little drawing to understand how I intend to use the HEB beams, it only shows one side of the X axis, intended to be used as an unsupported rail.
    What do you think ?
    Thanks !
    cnc2.
    Attached Thumbnails Attached Thumbnails Need some FEA of HEB beams for a mechmate like router-sketch.jpg
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    just post the 3D model of Beam... Provide us the distributed/concentrated Load ...and I will do the FEM for you.
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Feb 2008
    earth
    Quote Originally Posted by Khalid View Post
    It's very kind to you Khalid, but I didn't make a 3d model yet & I have no idea on how to make one.
    I'm not sure on the design of the base of the machine, but I know that the table's legs/feet will support the X axis above the table surface, from there i'll have to find a way to secure the legs together to get rigidity on the frame.
    I'm afraid to overbuild it & I'm more afraid of having too much steel without achieving rigidity.
    I saw your machine, the one that has the tubes for Y axis & the 4th axis it was green I think, it looked like a light machine, is it rigid enough, what can it achieve depth@IPM.
    Thanks !
    cnc2.
    Apr 2006
    Pakistan
    OKay.. I will calculate for you HEB300 and 270cm length... How much the Gantry load?.. I suppose 50Kg... I defined the material A36.. I fixed both ends and aided 50 kgforce at the one side of surface throughout the 2700mm length...
    Will show you the results soon...
    Apr 2006
    Pakistan
    The model of H Beam was created as per standard dimensions given in the following Pdf:
    http://www.millstockstainless.com/documents/doc_34.pdf
    Both ends were fixed constraint.
    On one edge where the roller will move i applied 50kgf throughout the length (270 cm).. Following are the Von mises stress and displacement results..
    Maximum deflection 5.6mm...
    PS:
    You can add plate Braces to strengthen the beam edge.
    Attached Thumbnails Attached Thumbnails Need some FEA of HEB beams for a mechmate like router-displacement.jpg   Need some FEA of HEB beams for a mechmate like router-isolines.jpg   Need some FEA of HEB beams for a mechmate like router-von_mises.jpg   Need some FEA of HEB beams for a mechmate like router-beam_constraints.jpg
    Apr 2006
    Pakistan
    I added 10mm plate triangular ribs at both sides equally spaced at 27cm.. but i didn't find improvement in the Displacement readings..
    If someone else calculate it and show us the results for comparison. I took the Material A36.
    Attached Thumbnails Attached Thumbnails Need some FEA of HEB beams for a mechmate like router-beamwithrib.jpg   Need some FEA of HEB beams for a mechmate like router-beamwithrib1.jpg   Need some FEA of HEB beams for a mechmate like router-spaced.jpg   Need some FEA of HEB beams for a mechmate like router-vonmises.jpg
    Feb 2008
    earth
    Thumbs up
    Wow, thanks Khalid !
    HEB300 is not what I want, it's too big too heavy, I want to use HEB100 a bit differently from how you analyzed it, sorry I thought it was obvious for the side loads.
    Look at the following drawing in order to understand what I mean, do you understand now, why I want the rail beams to be supported only at the ends ?
    It'd be cool if you could do the same for loads from the sides & for the load of the gantry which will weight up to 100Kg max. If you can test with side loads needed to flex the beam by 0.1mm it'd be great.
    Thanks !
    cnc2.
    Attached Thumbnails Attached Thumbnails Need some FEA of HEB beams for a mechmate like router-bb.jpg
    Apr 2006
    Pakistan
    Okay.. but the bearing you will use at top will be Qty:04Ea and the same amount at the bottom... This will distribute the 100Kg load /8= 12.5 Kg at all the supported locations!!!!
    The same will true for the side bearings, i guess two each at both sides..Total 04 ..so side load will be170/4 = 42.5Kg...
    Now as the Y-Gantry is supported at two sides so total load at one side will be:
    12.5 Kg/ 2= 6.25Kgf Vertical Load
    42.5Kg/2= 21.25 Kgf Side load
    Tomorrow i will make some calculation on above basis and will show you the results..
    All above posted pictures are considered wrong...
  • Page 1 of 10 1234 ... LastLast
    1. Introducing the "full-size" MechMate router
      By Gerald_D in forum DIY CNC Router Table Machines
      Last Post: 08-24-2011, 07:17 AM
    2. EZ-Router to MechMate Comparison
      By dmoore in forum DIY CNC Router Table Machines
      Last Post: 05-29-2011, 04:37 PM
    3. how can I combine two beams ???
      By cosmo2 in forum Mechanical Calculations/Engineering Design
      Last Post: 09-19-2009, 06:34 AM
    4. 2 or more CO2 Laser beams combining?
      By Konstantin in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-21-2009, 01:08 PM
    5. How to combine two CO2 laser beams?
      By jlew in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-18-2007, 08:29 PM
