Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 05-29-2005, 03:54 AM
gearcut is on a distinguished road
Question units per inch math
hi what is the formula for computing steps per inch
for example 360/.9 degree half step=400 steps per turn.
so 400*20tpi lead screw=8000 steps per inch.* 30:1 gear reduction
ie 8000*30 =240000 steps will give me 1 inch.
is my math correct or did my brain fart?
Old 05-29-2005, 07:06 AM
jeffery71 is on a distinguished road
Yes your math is correct... Are you sure its 30:1 and not 3:1 ???
I think 30:1 will be a big problem for you.
That would give you a resolution of .000004 wich is way to much.. would also really limit the speed of your unit..
Old 05-29-2005, 07:16 AM
OCNC is on a distinguished road
(steps/rev)*(rev's/rev)*(rev's/inch)=steps/inch
Old 05-29-2005, 12:24 PM
ViperTX is on a distinguished road
Hmmm...that gives me step *rev's squared/inch rev squared
Old 05-29-2005, 02:02 PM
[(step)*(rev^2)]/[(inch)*(rev^2)]
The (rev^2) cancel and the units remaining are step/inch where inches are the linerar inches of travel.
math needed to build a cnc trubleshtr Mechanical Calculations/Engineering Design 1 03-16-2005 02:20 PM
DRO - Metric or Inch DJ Morrow General Electronics Discussion 2 11-15-2004 03:06 PM
Turns per inch to metric conversion sixpence DIY-CNC Router Table Machines 1 08-28-2004 03:19 AM
turns per inch vs threads per inch pminmo DIY-CNC Router Table Machines 12 08-18-2004 10:27 AM
Metric vs Inch - arguements pro & con DJ Morrow Mini Lathe 10 08-12-2004 09:46 AM
