| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
| 2 motors on xaxis with rack + pin Hi all, Would just like to know, wot u pros think of using rack and pinion on x axis with 2 motors, 1 either side, before i start to get parts made to fit this i would really like to know pros and cons, My rack is module 2 20mm and my pinion is 12 tooth 20 degree angle, Now i know after having bought this rack and pinion and fixing it to my system that 12dp isnt ideal and 24 would be better, but will this work, before i spend more money on this headache, i was thinking of direct driving these pinions with 300 oz inch steppers, and each rotation of pinion moves 3". Thanks in advance for any replies. Appreciated DeeDee |
| Your idea will work but I worry about the fact that you have two separate motors not physically linked. If one motor would loose a step or two then that would put the gantry in a bind. A lot of commercial machines use one motor turning a drive shaft linked to the pinions on either side. With this method the only way it could get in a bind is if a pinion would jump the rack. If there is this much play in your system then you have done something wrong in your design. If the commercial guys do it then there must be a good reason for it. K.I.S.S.- keep it simple stupid
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| Many of the large commercial tables use motion control systems that are capable of 2 motors running independantly, rack & pinion on either side, with one encoder slaved of the other (master). Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I run a commercial router with the set-up you are refering to - two motors, two racks. It is a very common arrangement - especially on larger gantry machines. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| I dont like the idea, even if professional companies do use it. I have a new customer who has this arrangement on his machine, and he is finding he has problems with racking. Sometimes the steppers get out of sync and then continues to drive the gantry skewed for the rest of the cut. I cant imagine what this does to the linear bearings. I have taked him into a retrofit ( I have jumped into the deep end here) I have suggested we use just one big servo and a drive shaft across the gantry to connect both sides to the one servo. To me there is something more honest about this approach. Its a mechanical link, its simpler, it only requires one servo and servo drive card, less chance for future problems. ETC But that is just my opinion. Just remember, the more technical something is, does not necesarily mean it is better. Sometimes mechanical is still superior to electrical. |
| Benny, I have a couple of customers that have a couple of these Plasma machines with this system for over 10yrs and still running 16hrs a day. Al.
| I'm planning on using the two motor system with racks and pinions.... I would bet that those that have problems with the "slaved" drive are using under-powered motors or are not tuning their systems within its capabilities. Otherwise I have heard and read of many successful dual drive systems. |
| No argument guys. I was just telling my story and my customers story with his "professionally" built machine. Yes Bloy, the steppers on my customers machine are surprsingly small. I was very surprised when I saw them. Actually I mught have a picture of them. Last edited by ynneb; 05-28-2005 at 12:19 AM. |
| Here are the pics. Wouldn't you agree these steppers are surprizingly small? |
#10
| I hear ya on the horror stories....I have had issues before but they were caused by an abnormal event. If the motors are sized properly for the equipment I can't see there being a problem under normal conditions. Having a dust collection boot hang up on the edge of the table or fence, for example, is not normal......not that it's ever happened to me.... Squaring the gantry during referencing is a consideration and a must with open-loop, independent drives. Scott
#11
| Generally, when this question comes up, you're going to have people tell you it works fine, and people tell you all the things that can go wrong. As long as you don't have underpowered motors, you really shouldn't have any problems at all.
#12
| Motor size Hi everyone, Thanks all so much for the replys, I have 2 300 oz inch steppers that i am intending to use, the gantry would weigh around 120lb's or less, would you all think that these motors are enough for this machine, also what all is involved with setting up master and slave steppers, i am starting with a hobby cnc board, but i am thinking of upgrading to to geckos, or are there any other boards that would best suit my application. Thanks again. DeeDee |
| Does anyone know of a controller board for synchronized stepper motors | Yellowbeard | Stepper Motors and Drives | 2 | 04-04-2005 12:06 AM |
| Looking for controller board for synchronized stepper motors | Yellowbeard | General Electronics Discussion | 0 | 04-02-2005 09:50 AM |
| Troubleshooting the Simple BreakOutBoard and L297 driver | pigifly | Open Source Controller Boards | 38 | 11-10-2004 03:13 PM |
| DB25I/O and software | pminmo | General Electronics Discussion | 4 | 08-13-2004 09:27 AM |
| Rack and pinion and stepper motors | Apples | DIY-CNC Router Table Machines | 17 | 05-22-2004 08:53 PM |
