Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
  #13
Old 05-28-2005, 02:47 PM
ger21's Avatar
If you use Mach2/3 to control your machine, all you have to do is check a box in the software to slave one axis to the other. You should also have a seperate home switch on each side, and Mach2/3 will square the machine when you home it.
  #14   Ban this user!
Old 05-29-2005, 06:40 AM
DEEDEE is on a distinguished road
Great to hear that Ger,
I havnt got mach as yet, how ever i think i will get it, could you also tell me do you think 300 oz inch steppers are good enough for the job, i was wanting to direct drive them as it saves me allot of agro trying to use gearboxes or pullies to get them geardown,
Thanks for your Help, much appreciated :-)
Old 05-29-2005, 07:02 AM
ger21's Avatar
I've never used rack and pinion, but from what I've read, they should work fine IF you gear them down at least 3:1. I'm not sure how well they will work direct drive.
You can download MAch2 or Mach3 and start using it right away, to see how it works. At the end of the install, if you uncheck the box that says load driver, it'll run in simulation mode. It's free for use with less than 1000 lines of g-code.
Old 06-23-2005, 12:12 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
ger21 -
3:1 - is this a decent rule of thumb for R&P?
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-23-2005, 01:01 PM
ger21's Avatar
Originally Posted by mxtras
ger21 -
Scott
Not sure, but you want to gear it to get decent resolution.
Old 06-23-2005, 01:19 PM
Al_The_Man's Avatar
One method I use enables me to get the lowest inertia ratio and fastest accel/decel rates and that is to find out the top rpm of your motors, the travel/rev of the pinion, and the desired top feed rate and go with the highest reduction ratio you can, in keeping with the method you intend to use for gearing etc.
BTW here is a sizing program I have used for quite a while, I believe this is the only site you can get it now, it was originally put out by Emerson (Emersize) in the 90's.
The advantage is you can enter you own 3rd party motors and amps.
http://www.macphersoncontrol.com/navbar/mcptools.html
  #19   Ban this user!
Old 07-10-2005, 02:38 AM
bobgerman is on a distinguished road
A good commercial dual motor system will use servo/encoder Vs steppers to avoid the issue of missed steps. I work in a shop with all kinds of CNC equipment (mostly Amada) The press brake back guages use dual servos...we also have a shear using a cross-over shaft to keep the guages locked together. If you're useing rack and pinion (on both sides) it would be as simple as just adding an idler shaft anywhere convenient to lock the two sides together.
Does anyone know of a controller board for synchronized stepper motors Yellowbeard Stepper Motors and Drives 2 04-03-2005 11:06 PM
Looking for controller board for synchronized stepper motors Yellowbeard General Electronics Discussion 0 04-02-2005 08:50 AM
Troubleshooting the Simple BreakOutBoard and L297 driver pigifly Open Source Controller Boards 38 11-10-2004 02:13 PM
DB25I/O and software pminmo General Electronics Discussion 4 08-13-2004 08:27 AM
Rack and pinion and stepper motors Apples DIY-CNC Router Table Machines 17 05-22-2004 07:53 PM
