Hello,
I've just finished my 1st machine and am well into designing my #2. I'm not keen on having hi-speed acme rods/ballscrews shipped here in my neck of the woods home so I'm designing a belt-driven set-up ala buildyourcnc's. It will be made from MDF or 13ply Marine plywood that's available 400miles away. Y gantry weighs from 15-20kgs (33-45 lbs). Two Belts will be used in either side of the gantry and another for the Y. I will scrounge for used ballscrew for the Z axis.
here are some questions:
Machine size is 28" X 54", cutting area approx 20" x 44". Will a T5 10mm(3/8") wide belt enough for the X axis? I have no prior experience with these so I have no idea how they might hold up under tension.
My choice of 10T 5mm pitch pulley has a hub width of 16 mm. Will the 10mm wide belt be useable for this? Wont the belt "dance" in such a not too tight space?
OR can you suggest some other belt size suitable for my router?
Thank you very much in advance.
Jordan
Check this link, all the timing belt information needed to answer your questions and more. A great resource. Be sure to bookmark.
http://www.sdp-si.com/web/html/reference_library.htm
