Originally Posted by
tds11223
I want to discuss what actual part symmetry means and if symmetry can also be called true position. Concentricity from one surface to another as well. I would like all opinions, questions, ect. to be discussed. For instance, if a blue print has a datum set on the O.D of a part, and two bores on a shaft are to be concentric to the O.D, does this also mean they must be concentric to each other or that they will be concetric to each other since they are both to be concentric to the O.D?
