Page 1 of 4 1234 LastLast
Results 1 to 12 of 37
Thread: wHAT IS IT CALLED ?
    Banned
    May 2010
    wHAT IS IT CALLED ?
    HI
    Refering to the figure, I am looking out for a substance which is made of rubber & has profile as shown in figure. It compresses as the slider pushs & decompresses as the slider moves back.
    It is used to avoid coolant & burr entry into the mechanism.
    I don't what it is called as...?....Can anyone help.
    If you aren't getting it, just imagine the rubber used on surface grinding machine.
    Zirok
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    A way cover?
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Registered apache405's Avatar
    Jan 2007
    accordion type way cover.
    -Jeff
    Jul 2005
    Pleated cover, pleated strip?
    Corrugated rubber?
    Feb 2007
    U.S.A.
    Question
    Zirok,
    A Gortite accordion bellow cover?
    Jeff...
    Registered Weldtutor's Avatar
    Oct 2005
    Question Whatzit
    It looks like a "blue rubber thingy."
    Dec 2003
    As Jeff said, Gortite is a common supplier.
    http://www.gortite.com/index.html
    I got the round versions for my ballscrews.
    Banned
    May 2010
    hI
    Well thanks everybody for wonderful contribution.
    One more query remains that how it is attached.
    Refering to the figure, you can see a slider(shown in red) & the guideways shown in blue.
    How to attached WAY COVER here.??
    Zirok
    Dec 2003
    There is no indication of how large the mechanism is, but it appears your slideway is below the blue area?
    If you want to cover it from the top, you may be able to use ordinary industrial rubber sheet material, you normally would attach it to one end the fixed part the other to the extreme end of the moving part, in the picture and using rubber sheet it could simply concertina up when the slide is fully retracted.
    This is the way many small knee mills cover the ways.
    Banned
    May 2010
    Thanks for the reply
    As shown in Picture 456, I understand that you are saying to glue one side of way cover to Part A ( which is stationery ) & the other to the moving Part B.
    Am I right ?
    Also does the rubber has a linear sort of (as shown in picture 130 in green colour ) which needs to be attached {WITH HELP OF GLUE} between the sideways (Part C & D...see picture 909)
    Zirok
    Attached Thumbnails Attached Thumbnails wHAT IS IT CALLED ?-456.jpg   wHAT IS IT CALLED ?-130.jpg   wHAT IS IT CALLED ?-909.jpg
    Dec 2003
    The material I have used in this manner for short spread areas is from a local rubber sheet supplier and is just plain flat 1/8" material sold in about 48" widths, I am not sure of the exact composition.
    I usually attach it with a simple 3/4" wide metal strip using #10-32 screws drilled and tapped at the attachment points each end.
    Banned
    May 2010
    Any Snaps/Images of the procedure will be really thankful & easy to understand.
    Zirok
  • Page 1 of 4 1234 LastLast
    1. What is this tool called?
      By jkittle99 in forum General Metalwork Discussion
      Last Post: 05-04-2009, 12:10 AM
    2. New Machine Build- What are these called?
      By Steve Crum in forum Stepper Motors and Drives
      Last Post: 07-05-2008, 01:41 AM
    3. What was this Bridgeport called?
      By gtrjunkie in forum Bridgeport and Hardinge Mills
      Last Post: 08-19-2007, 07:21 PM
    4. What is this called and where can I order it?
      By Alex_Cole in forum Benchtop Machines
      Last Post: 01-23-2007, 06:46 AM
    5. What are they called
      By Rhodan in forum CNCzone Club House
      Last Post: 08-23-2006, 01:29 AM
