Results 1 to 4 of 4
Thread: Ratio Calculation For 3 pulleys
    Jul 2008
    I know how to calculate 2 pulleys ratio but when 3 pulleys I have a little problem.
    For example driver pulley is 10" diameter driven 30" pulley the ratio would be
    3/1 or 3:1
    How are about driver pulley is 10" turn the 20" driven pulley and the 20" pulley turn the 30" pulley.
    How do you calculate this problem?
    Dec 2006
    the basic rule is to work them in pairs and then muliply the results:
    10/20 = 1/2, 20/30 = 2/3
    1/2*2/3 = 1/3
    however, because the 2 middle pulleys are of identical size then and only then you calculate as follows:
    driver pulley/driven pulley = 10/30 = 1/3
    1/3 * motor RPM = output RPM
    Motor RPM/output RPM = Reduction ratio which in your case would be 3:1
    Best regards
    Bruno
    Jul 2008
    thank you
    Moderator HuFlungDung's Avatar
    Mar 2003
    Just a comment: in a two stage reduction as was proposed, the center pulley must be a compound pulley or gear with two single components fixed side by side on a common shaft or hub. If these two components are exactly the same size, then they are considered to only be an idler and have no effect on the ratio, as Bruno alluded to, although perhaps implying that there was a 'special rule', but that is the basis for it.
    If you have a 3 (or more) gear train with a 10 driving a 20 driving a 30, the center component(s) are still idlers and have no effect on the ratio, they are merely motion transmitters.
  1. help with ratio....please
    By Grunge-Fut in forum General Waterjet
    Last Post: 09-09-2008, 02:33 AM
  2. ratio on x y table
    By dgalaxy in forum Machines running Mach Software
    Last Post: 06-24-2006, 10:40 PM
  3. gear ratio help
    By Erick Davidson in forum General Waterjet
    Last Post: 05-30-2006, 11:04 AM
  4. Gear ratio calculation spreadsheet
    By Splint in forum CNCzone Club House
    Last Post: 07-09-2005, 11:49 AM
  5. Poly pulleys vs steel pulleys
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 03-09-2004, 10:01 PM
