Results 1 to 3 of 3
Thread: Extending a piece of 80/20
    Gold Member eaglezsoar's Avatar
    Feb 2010
    I searched these forums but could not find an answer on how to extend a
    piece of 80/20, the 1530 series in particular.
    Obviously the best thing to do would be to buy a piece that is the length you
    need but there should be a way to extend a piece that is reasonably strong.
    I looked at the connectors available through 80/20 but could not find a connector designed for what I need to do. Does anyone have an idea that would work and would be strong?
    Jan 2006
    I don't know what loads are required but probably the strongest would be:
    part# 3370 - 6 total
    Then on top of those(if they will still fit):
    part# 4305 - on the 1.5" sides
    part# 4365 - on the 3" sides
    To get better than that you would probably have to overlap the joint with two short pieces of extrusion, one on either side.
    Matt
    Feb 2010
    Thank you Matt.
    That's exactly what I was looking for.
    I looked at the catalog and did not see the #3370
    The #4365 was exactly what I needed for the sides.
  1. Extending the Life of Coolants
    By coolantman in forum General Metalwork Discussion
    Last Post: 04-02-2009, 10:44 AM
  2. Need Help!- extending the table
    By EStegall in forum Want To Buy...Need help!
    Last Post: 10-17-2008, 01:44 PM
  3. Extending RS232 over long distances
    By jderou in forum General Electronics Discussion
    Last Post: 11-04-2006, 07:23 AM
  4. Extending text to a surface?
    By lotsa luck in forum BobCad-Cam
    Last Post: 02-24-2005, 08:21 AM
