Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 04-27-2005, 09:57 PM
rc-cellar is on a distinguished road
Questions about timing belts & gears
OK, I want to add some reduction to my DIY router. I have 360oz servos and THK 5mm pitch ballscrews. (300ipm rapids are scary!!)
I'm thinking in the 3:1 range, and am checking out the McMaster catalog....
I'm leaning toward 3/8"width, .2" pitch .... will this be adequate?
How much backlash can I expect ? (near zero now)
Will they need to be accurately tensioned ?
Do I need a tensioner device (spring-loaded idler) ?
Will they stretch ?
How often will they need replacement ?
Any input/ opinions would be much appreciated. Thanks
If it ain't broke... fix it 'til it is.
Old 04-27-2005, 11:09 PM
Al_The_Man's Avatar
Check this site, they have design criteria and formula's etc
http://www.sdp-si.com/
Planetary gearhead vs timing belts Swede General Metal Working Machines 4 03-27-2005 08:19 PM
Timing Belts chas DIY-CNC Router Table Machines 1 01-19-2005 09:03 AM
Cheap Source for Timing Belts and Pulleys? samualt DIY-CNC Router Table Machines 10 09-10-2004 06:41 AM
pully gears and belts for servos replicapro Benchtop Machines 3 07-22-2004 04:23 PM
Timing belts, gears, and ratios samualt DIY-CNC Router Table Machines 11 12-19-2003 07:09 PM
