Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 02-25-2010, 05:46 PM
jason07's Avatar
jason07 is on a distinguished road
Fly Cutter
Hi Guys,
I'm a MTT student at NTI and I'll be starting a fly cutter project next week. Similar to the one below.
How should I go about milling the angled head? I considered using a 10 degree angled wedge underneath the part,but i'm open to suggestions if you have a better idea.
Thanks.
Old 02-25-2010, 06:01 PM
packrat is on a distinguished road
When I made one (45 years ago) I held it horizontal in a vise and turned the vise to the angle. Then used a woodruff key cutter to make the slot. While it is still set-up for that cut, drill and tap your holes, saves an extra set-up.
good luck, cary
Old 02-25-2010, 07:31 PM
jason07's Avatar
good luck, cary
Thanks. That did'nt even occur to me. One of the Bridgeport vises is already setup with an angled vise.
Old 02-26-2010, 11:40 AM
I forgot to say that your better off machining the angle and slot first then turn the shank. Gives you more to hold on to while doing the milling.
cary
Old 03-04-2010, 03:24 PM
jason07's Avatar
Hi Guys,
I thought I would share a pic. of my flycutter project at school. The slop in the bridgeport screw threads cost me a 0.050 mistake,but it's on the outside and not going to affect my tooling slot. Next i'm going to turn the finish diameter,then i'll drill and tap.
Yesterday
Today
Enjoy.
Old 03-19-2010, 06:53 PM
jason07's Avatar
I've finshed the fly cutter project. here are some pics.
In the lathe turning the shaft and trying to put a 1/4" radius at the base.
I followed the blueprint and my set screw holes were'nt centered. After I double checked the measurements, it was the blueprint and not my mess up. So I drilled three holes in the top slot and the tap broke off in the last hole and I could'nt get it out so I welded up the hole.
Finished fly cutter. My instructor showed me how to chuck the fly cutter in a 3/4" collet and turn the 2.125" diameter on the bridgeport mill. If you have'nt done it or seen it done before let me know and i'll go into more detail on how it's done.
Enjoy.
Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) dharschman Toolgrinding & Toolgrinding Machines 3 09-13-2010 12:25 PM
CNC Laser cutter versus CNC Plasma cutter? squale Laser Engraving & Cutting Machines 10 04-26-2009 04:59 PM
Tool & Cutter Grinder and Wire Cutter Plans newport CNC Wire Foam Cutter Machines 1 04-17-2009 04:15 PM
Cutter comp on an id hole< cutter diam.?? PaintItBlue Haas Mills 5 05-05-2008 06:30 PM
How do I use a dove tool cutter & slot cutter bobby1 BobCad-Cam 2 04-15-2008 08:06 PM
