Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 02-25-2010, 01:16 PM
MikeBo is on a distinguished road
Trolley Beam Load
I have a w12x40 trolley beam that spans 21'. It is welded to a W10x49 at both ends. There is a W5x16 beam welded to one of the columns that angles down at approximately 50 degrees and welds to the top of the trolley beam at the midway point. I want to know if the trolley beam can handle an 11,000 lb. load that will be trolleyed to one end of the beam.
Thanks,
Mike
Need Help!- How align IR beam (co2) with visible beam (red dot laser) ? etienne delcuve Laser Engraving & Cutting Machines 7 02-04-2009 05:41 AM
I-Beam Cantilever Weight Load Capacity ? Dan150 Mechanical Calculations/Engineering Design 6 05-27-2008 07:29 AM
I-Beam load capacity? DennisCNC Mechanical Calculations/Engineering Design 45 09-29-2007 02:17 PM
Master Slave Trolley Arangements? technomage Linear and Rotary Motion 0 05-23-2007 04:36 PM
Short beam/Long beam? - Basic design Pat2000 Mechanical Calculations/Engineering Design 5 11-09-2005 10:49 PM
