Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 02-24-2010, 01:08 AM
Sturgis is on a distinguished road
Thumbs down Gearing and torque calculations
I run a motorcycle starter unit with a 1.4kw starter.
the gearing is 15 tooth on starter, 11 tooth on 50mm roller (front) and 19tooth on 76mm roller (Top). Chain driven
I need to figure out how to increase torque V speed without losing too much speed in the process. Is there a site or chart that I can access to determine the best scenario?
Any help would be grateful
Regards
Sturgis
Constant Torque vs. Varaible Torque VFD robhrzic Phase Converters and VFD 24 02-16-2012 07:46 PM
What gearing should I use? 1armsbandit DIY-CNC Router Table Machines 22 01-17-2010 04:50 PM
Gearing ???? VSNT DIY-CNC Router Table Machines 17 08-31-2007 12:51 PM
Gearing down... snooper Mechanical Calculations/Engineering Design 9 08-02-2006 11:26 PM
Need help on Gearing CAM_MAN DIY-CNC Router Table Machines 8 04-05-2006 12:23 PM
