Automotive 6&4 rib serpentine pulley profile.
Results 1 to 12 of 12
Thread: Automotive 6&4 rib serpentine pulley profile.
    Oct 2007
    Default Automotive 6&4 rib serpentine pulley profile.
    Does anyone have a print, or know where I can find the exact dimensions and the radius amount for each rib. Im trying to design a pulley and am lost at this point on where to look for the groove depth's, spacing, and the root and top radii. I dont want to design a belt shreader!
    Member Bubba's Avatar
    Mar 2004
    lagrange
    I thought I had that info, but I can not find the automotive specs. Seems I saw it on the Gates site (www.gates.com) someplace!
    I have the industrial specs and if memory serves correctly, there is a slight difference:{(
    Art
    Oct 2007
    Just spent 20minutes on the gates site and found everything but sepentine belt dimensions. Its gotta be on there.
    Jul 2005
    Machinery Handbook 28th Edition, page 2427 to 2429. I think it is a V- Ribbed belt is'nt it?
    cadfish
    http://www.burgiengineers.com/
    Oct 2007
    Thank the lord for the Machinist Bible.
    Im not sure which profile it is though, im thinking profile K because the gates automotive belts all start with a K on the part number. For example, K060375 is a 6 rib, 37-1/2" long belt. ( I used to work at the parts store in high school).
    EDIT:
    Just measured (as close as I can) a pulley I have here off a mustang and im getting a .140" center to center of the grooves. Machinists bible is calling that dimension (pitch) and its for the K Profile. I think we have it!
    Jul 2005
    Do you have the belt? If so there are some measurements I can give you to determine the size.
    the (thickness/distance between ribs) of H=(.12/.063) J=(.16/.092) K=(.24/.140) L=(.38/.185) M=(.66/.370)
    cadfish
  7. #7
    Jul 2005
    Default I hope you have Excel
    I Tried taking a Picture and never got a readable picture so see attached.
    Attached Files Attached Files
    cadfish
  8. #8
    Feb 2007
    Full profile dimension drawing here. page 4
    http://mechatronica.eu/en/design-man...%20(38-42).pdf
  9. #9
    Aug 2005
    Afghanistan
    Default Serpentine belt
    Try the SAE ( Society of Automotive Engineers ) handbook. Any large library should have a copy.
    Ernie
  10. #10
    Oct 2007
    Thanks a ton guys. This site saves the day once again!
  11. #11
    Oct 2007
    I finally got a few free minutes and drew up generic Poly-V 6 rib pulley. I also found out that Tool-Flo makes formed inserts for these profiles. Can somebody verify my .dxf drawing is correct. .140 groove pitch, and K profile.
    Just want another set of eyes to check it out.
    thanks!
  12. #12
    Sep 2006
    UK
    Quote Originally Posted by aaron p View Post
    thanks!
    I manufacture vee pulleys, we have special tips made to produce the correct depth/pitch rad.
    In metric, the pitch is 3.56 and the depth is 6.80.
    Pm me if you need more info ,. cheers chris
