Design ideas for my router/plasma cutter.
Results 1 to 2 of 2
Thread: Design ideas for my router/plasma cutter.
    Apr 2013
    Default Design ideas for my router/plasma cutter.
    Thinking about a 4x8 machine, mostly for a router but I'd get a lot of use out of a plasma cutter too. What do you guys think of these ideas? Specificly, the spring loaded stepper motor. The built in plasma water table that can be drained and have a vacuum table dropped in. And the rail system.. angle iron, skate bearings on top and grooved on the side, running on the top of 2x6 C channel? 2x2 steel for the gantry. 20mm drill rod for the gantry and Z axis, with 1/2" aluminum plate for the Z axis. I'm not too enthused about my rail design, trying to balance durability with off the shelf parts. I may end up going with 20mm DIY linear rails there too.
    Design ideas for my router/plasma cutter.-screenshot-2017-07-28-20-47-25-a
    Design ideas for my router/plasma cutter.-screenshot-2017-07-28-20-47-57-a
    Design ideas for my router/plasma cutter.-screenshot-2017-07-28-20-48-32-a
    Design ideas for my router/plasma cutter.-screenshot-2017-07-28-20-49-01-a
    Design ideas for my router/plasma cutter.-screenshot-2017-07-28-21-33-05-a
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Design ideas for my router/plasma cutter.
    You need some type of gear reduction on that motor.
    UCCNC 2017 Screenset
