Need Help! Milling plaster on CNC
Results 1 to 2 of 2
Thread: Milling plaster on CNC
    May 2017
    Brazil
    Default Milling plaster on CNC
    Hello everyone,
    I'm a new Brazillian student on forum. I searched a little about this on forum, however a I could not find something about it.
    I'm studying about milling plaster on CNC, so my first step is find a American or European standards about this, because I will need do some machinability tests (Superficial analysis, Mechanical analysis of machined bodies, at first). But I could not find this yet. I would like to know if someone know it.
    Summing up, is there any American or European standards that tells me how I should do these tests so they are valid? (About plaster or some ceramics)
    Thanks a lot, I hope you understand what I mean.
    André Moreira
    Member awerby's Avatar
    Apr 2004
    Default Re: Milling plaster on CNC
    Plaster of Paris can be cut on a milling machine or router. It's a bit dusty, but it's soft enough that it won't dull tooling too much. I don't know where to send you for data or standards on this, but it's not too hard to design a test part and try it.
    There used to be a product called Rayite sold by USG as a machinable plaster. I tried it, and found that if I didn't let it dry thoroughly before cutting it the chips would stick to everything and make a mess. But when it was dry it made less dust than regular set plaster. My guess is that it was just regular plaster with a little PVA added for cohesiveness.
    Machining ceramics is another thing entirely. Green (unfired) ceramic machines easily, but it's hard to hold onto, while the dust is both toxic and abrasive, so you'd need to protect the sliding parts of your machine (as well as your lungs) if you're experimenting with it. Fired ceramic can be machined as well, but it's difficult and slow, requiring special diamond tooling.
