Need Help! Aluminum vs PSI
Results 1 to 11 of 11
Thread: Aluminum vs PSI
    May 2017
    Question Aluminum vs PSI
    Hey Guys, thanks for the help.
    A little background. At a college, I'm an officer in an Engineering Technologies group. We're planning on creating a submarine-like device to be used in a lake.
    I was hoping to make this "submarine" out of aluminum plates/sheets. Would this be a good idea? If not, what metal would you prefer? This device will be at a minimum of 10 ft. deep in water and 30 ft. maximum. We are unsure of the dimensions at this tie, but probably 4'x6"x6".
    May 2006
    Default Re: Aluminum vs PSI
    If you have a good engineering and good welder and BIG BUDGET go with aluminum,
    May 2017
    We have about $4k to mess around with for materials.
    Dec 2007
    Without knowing the full scope of your project. Possible look at an acrylic hull, 6"dia or 6"sq tubes are not that uncommon.
    May 2017
    Question Re: Aluminum vs PSI
    Thanks for the idea MConner, Anyone else have any ideas?
    Dec 2013
    6 inch (or larger) PVC pipe would work fine also. More than strong enough, and cheap.
  7. #7
    May 2017
    @Jim Haha, it's all good. Thanks for the input and advice.
  8. #8
    Dec 2013
    Quote Originally Posted by mcarter645 View Post
    I had to edit my post, my reading comprehension leaves something to be desired.
  9. #9
    May 2017
    Quote Originally Posted by MConner View Post
    And just cause I'm curious, which method do you prefer? Scoring the acrylic and breaking or using a circular saw?
  10. #10
    Dec 2007
    Mcarter, Scoring never works for me, especially with at tube. I would suggest first a miter saw (diablo blade), or a metal band saw blade. I am sure others on this site have better experience on what to use then I.
  11. #11
    Dec 2007
    Jim, Your idea is totally legit also, functional and elegant. I have a problem placing to much emphasis on the "Coolness" factor $$ .
Aluminum vs PSI
Aluminum vs PSI
