NEMA 34 shaft diameter specification
Results 1 to 3 of 3
Thread: NEMA 34 shaft diameter specification
    Oct 2007
    Default NEMA 34 shaft diameter specification
    I recently ordered a NEMA 34 stepper motor and found the shaft diameter was 0.62" diameter. I was under the impression all NEMA 34 motors had a 0.50" diameter shaft.
    Just curious if the NEMA spec specifies shaft diameter, or is it just the frame mounting dimension?
    Dec 2003
    Is it maybe actually a IEC mount and a 16mm shaft?
    Oct 2007
    I suppose it could be....the mfg calls it a NEMA 34 motor though.
