Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-18-2010, 10:41 AM
fbergski is on a distinguished road
Fusion 640T Hard Disk I/0
Do any of you Mazak gurus know the parameter to turn on the hard disk I/o feature for the Fusion 640T control? We have six machines in our shop, two of them are QT200's and they have the ability to transfer programs via a network to our Mazak server. The remaining four machines (SQT250 & SQT250MY's) do not have the ability to transfer programs to our Mazak server.
On the four machines under setup on the hard disk I/O page the I/O directory is grayed out and I cannot select a network folder I've called Mazak applications and so far they have not offered a solution. The four machines are physically connected to the network via a pcmia card and under network neighborhood see the shared Mazak folders on the server.
Anyone?
Thanks,
Philip
Old 02-18-2010, 11:38 AM
girishdk is on a distinguished road
Thumbs up Fusion 640T Hard Disk I/0
Is it possible to transfer HD -> Memory or HD -> ICcard ?
If no,
pl check on top of the screen any "Setting" or so Menu & check if there is any "Default Program Directory" setting & whether this directory exists in HD or not?
If yes,
i am not sure, but may be network folder mapping in CNC may be required.
For long (3-4years) i am out of touch with on PCFusion 640 controller, so the menu mentioned above may be different. It is only my opinion.
Regards,
Girish
Old 02-18-2010, 12:22 PM
I can transfer programs on all machines using the pcmia card slot on the front of the control. The issue is that on the four machines the "I/O folder" is grayed out and I cannot select a shared network folder to transfer programs too.
We have six machines which have combined have around 9000 programs that I need to get on the server. I cannot just copy the files from the t_backup directory.
Thanks,
Philip
FUSION 640T HARD DISK I/O fbergski Mazak, Mitsubishi, Mazatrol 0 01-28-2010 04:31 PM
pc fusion 640t strecha Mazak, Mitsubishi, Mazatrol 0 11-08-2008 10:00 AM
Fusion 640T--Can't edit program? ralph@nes Mazak, Mitsubishi, Mazatrol 2 09-30-2008 01:26 PM
FUSION 640T BIOS APEXWARRI Mazak, Mitsubishi, Mazatrol 1 01-22-2008 11:21 AM
PC Fusion 640T - fdd problem nicolabucci Mazak, Mitsubishi, Mazatrol 6 09-06-2006 12:59 AM
