Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-17-2010, 05:18 AM
jdc-machine is on a distinguished road
meldas 500 series
Hi there!! wonder if someone can help me??? I have a meldas 500series and would like to drip feed from my pc, but it doesnt work??!!
Old 02-17-2010, 07:35 AM
onthebumper is on a distinguished road
Did you try this http://www.meau.com/functions/dms/ge...00000472800000?
Old 02-17-2010, 07:43 AM
girishdk is on a distinguished road
Thumbs up Need Help! meldas 500 series
Try attached procedure, give feedback if any corrections needed.
Regards,
Girish
Old 02-17-2010, 11:59 AM
Sorry,
I think the default port no. for M500 series is 1. The attached procedure was prepared on basis of M60 series, but never tested.
So in the Step 2) set the par 6 Hostlink Port – 1, Device – 4. and not 2.
Regards,
Girish
Old 02-19-2010, 07:41 AM
girishdk,
That procedure is for Computer Link which requires additional hardware and option install on the 500 control.
Old 02-19-2010, 12:00 PM
Hi onthebumper,
You are right, this option is required.
As per feedback from our customers, for Die-Mould application with dripfeed, i think it is minimum required.
When using Dripfeed without HOSTLINK, i am afraid only 7-8 blocks will be transferred from PC to CNC buffer at a time.
With HOSTLINK i think 248-4096 blocks will be transferred at a time to NC buffer & hence the speed is more, finish better.
Above is our thinking from the feedback we received from our Die-Mould customers.
Any feedback of your experience is most welcome.
Thanks a lot & Best regards,
Girish
Old 02-19-2010, 03:04 PM
Girish
Yes you are correct. You can drip feed without Computer Link option but the finish on the part will not be so good if you are doing small movements like Die/Mold is doing.
Computer Link option is much better for Die/Mold because of the buffer.
I just wanted to clarify that the option would need to be purchased to follow your procedure.
Ethernet option for 500 control is also a very nice option for Die/Mold with much higher speeds and better reliability, in my opinion.
Old 02-20-2010, 02:49 AM
Talking meldas 500 series
thanks for all your feed back guys,will try all of the above and see if it works.
Need Help!- How to initial parameter error meldas 300 series gunawan_tehnik Mazak, Mitsubishi, Mazatrol 5 03-24-2012 05:07 AM
Need Help!- problems while booting MELDAS 300 series CNC LEADWELL TDC 450. perfect Mazak, Mitsubishi, Mazatrol 3 02-09-2012 03:16 PM
Need Help!- Meldas 500 Series ScoobyDoo OKK 1 10-05-2009 09:24 AM
Need Help!- MELDAS 300 series DANMI38 Mazak, Mitsubishi, Mazatrol 2 03-09-2009 10:59 AM
meldas 50 Series nastek Mazak, Mitsubishi, Mazatrol 5 12-31-2006 09:32 PM
