| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Just wanted to know if anyone has used them and can you take a deep cut (.25) with them or more like (.05) each pass. Would love to buy one used and give it a try any info would be great. Thanks for the help guys. |
| The nature of the drive train and spindle bearings make this tool less capable than a typical milling head. All the stuff that makes the driven tool block robust is less for angle adjustable. I would consider it for light milling only. It's better suited for drilling. my opinion only. jim |
| Don't have Miltiplex but did have it on SQT and it's depend what you want to do with it. I don't think it mean to cut some exotic material, the cutter drive by gear and the ball bear is not like normal milling by said that I didn't said it won't cutter, you will have hard time to push it through. Don't be disappointing yet, depend what your company mostly doing. If most of the job you have in house that invole sometype of angle pocket, drill or tap etc. It's definite worth it to look into, it will save you second setup opertion and since you are doing everything in one setup the deviation will be reduce. In short said with common material, it will be great. Con, the dam unit itself is too expensive. 7 of those tools can buy a new HAAS milling.
__________________ The best way to learn is trial error. |
| Tags |
| 6300, adjustable speed motor, live tooling, mazak, universal |
| looking for live tooling | supreme | Want To Buy...Need help! | 0 | 11-27-2009 11:34 AM |
| IBAG Adjustable Right Angle HS Spindles | wardcomm | Product Announcements & Manufacturer News | 3 | 08-05-2009 10:46 AM |
| LIVE TOOLING? | WOLOG | OneCNC | 9 | 03-17-2009 02:46 AM |
| live tooling | guhl | Fanuc | 0 | 02-12-2008 01:43 AM |
| What is Live tooling versus "non-live tooling"? | squale | General Metal Working Machines | 8 | 11-15-2007 02:38 PM |
