Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-12-2010, 10:00 PM
pwtooling is on a distinguished road
MAZAK QT18 MS
Need Set Up Help - I Have a Qt18-ms I want to turn a shaft 240mm long 15mm dia. using the sub spindle to support the end and sink both chucks can this be done or is there a easier way for shafts on this type of mazak?
Old 02-13-2010, 09:04 AM
jimiscnc is on a distinguished road
If you can turn a cylindrical portion at the first feed out to grab you should be OK.
turn short O.D. at Head 1
Grip turned dia with Head 2
Pull out stock full length with Head 2.
Synch both spindles - I think this can be done at the beginning?
Turn O.D. wiht both spindles synched.
cut-off without a lot of revs at blade break through.
pretty sure everything is possible with the enlightened use of mazatrol transfer units?
-jim
Old 10-19-2010, 05:41 AM
florinblaga is on a distinguished road
I have same kind of machin and i don't know how to set manyal the tools
the tool eyw is not working
coud you help me?
New guy needs help with Mazak fat kid Mazak, Mitsubishi, Mazatrol 2 02-08-2010 01:40 PM
Need Help!- Mazak QT-10 T2 manuals --acct w/ mazak? CDTINC Mazak, Mitsubishi, Mazatrol 0 06-30-2008 08:42 AM
Mazak mprotic Mazak, Mitsubishi, Mazatrol 0 08-09-2007 06:06 PM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
Mazak uav G-Code Programing 19 05-20-2007 02:12 PM
