| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
New here, So I'll start by saying hi. I'm new to Mazatrol and have been running a vertical Milling center with the M640 controller. The shop will only use mazatrol, they do not want any EIA programming. Some problems I seen and am curios about are with the WPC. One program I came across, had 180 degrees in the theta for two of the four WPC's. Fixture was running four parts, with two of them loaded at 180 degrees. It auto probed a bore at each location for X & Y. The two that were rotated had error in the WPC pick-up. I moved the 180 from the WPC to an offset to fix the problem, but still am curious of why it was not picking up the proper location. |
| Check your auto probe pattern parameters, make sure that the parameters are setup for this type of fixture and that the auto comp/calc parameters are correct. These parameters are in your parameter manual. Htech. |
I have run into many problems when probing when there is an angle in theta in the wpc. I believe the problem comes from the parameters that are set when the probe is calibrated. The controler does not properly figure out the wpc if the angle is 180 I dont think the machine flips the parameter. The way to program around this problem is to set the wpc theta to 0 then use a probing unit to probe the hole. Next just insert an offest line with the 180 degrees you need to flip the program around. |
| mazatrol T4 ram parity error | ddareddevil | Mazak, Mitsubishi, Mazatrol | 8 | 10-25-2010 07:35 PM |
| Problem- mazatrol m32 FLD Error | M42 | Mazak, Mitsubishi, Mazatrol | 25 | 12-10-2009 01:12 AM |
| Need Help!- Mazatrol T32 - PARITY ERROR | maro | Mazak, Mitsubishi, Mazatrol | 0 | 06-25-2008 05:53 PM |
| mazatrol m-2 sum check error | bishop world | Mazak, Mitsubishi, Mazatrol | 2 | 06-26-2007 06:05 PM |
| mazatrol pc-fusion 640 error.... | monkei | Mazak, Mitsubishi, Mazatrol | 3 | 06-02-2006 06:42 PM |
