Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-28-2010, 04:31 PM
fbergski is on a distinguished road
FUSION 640T HARD DISK I/O
I have a QT200 with a Fusion 640t controller. I've networked it to a network and everything works fine. The only problem is when I use the "Hard Disk" feature and save a file to the network it deletes any file in the backup folder.
I have about 6000 programs to save on five machines so I've been using the page select to send multiple files. All was going well until I decided to check to make sure the file were all their. No luck, only the last save was their. Had a similar issue on our Integrex but was able to solve problem by deselecting the append option.
I called Mazak apps and have yet to hear back. I know there has to a parameter under the "ext parameters" page but cannot find any parameters in the Mazak manual for "Hard Disk" operation.
Can anyone help me out?
Thanks,
Philip
pc fusion 640t strecha Mazak, Mitsubishi, Mazatrol 0 11-08-2008 10:00 AM
Fusion 640T--Can't edit program? ralph@nes Mazak, Mitsubishi, Mazatrol 2 09-30-2008 01:26 PM
MAZAK FUSION 640T PROBLEM APEXWARRI Mazak, Mitsubishi, Mazatrol 8 07-30-2008 09:16 PM
FUSION 640T BIOS APEXWARRI Mazak, Mitsubishi, Mazatrol 1 01-22-2008 11:21 AM
PC Fusion 640T - fdd problem nicolabucci Mazak, Mitsubishi, Mazatrol 6 09-06-2006 12:59 AM
