| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
I have a leadwell MCV-0 with a Meldas MO control. Yesterday I had a Resolver die on my X axis. I had a replacement, put it on and adjusted the resolver voltage on the card. Now it seems like te x-axis is traveling a bit short. The first part I ran was about .01" off in x length from the part I ran before the resolver died. Also the holes I was interpolating after were .003" smaller in the x plane than the y plane. I adjusted the gain to be pretty close to the Y axis (~33 @1000mm/min) Anyone have any ideas? Thanks, Eric |
| its not home position,thats got nothing to do with a round hole being out of round,i would check to make sure the new resolver is tight,ive seen a loose one do that,also check the backlash,could be in there,and check your motor coupling,if that all checks out i would have to say more fine tuning is needed possibly in the parameters |
Thanks for the replies, I made sure the resolver to motor connector was tight when I assembled it. And I am using the same motor so the drive pulley shouldn't be an issue. I checked the backlash( using a DTI and a short program to move the axis out then back) I adjusted the gain to be as close to the y axis as possible. I adjusted the voltage of the resolver signal (with a scope) I am at a loss what else to do. There must be a way to adjust the distance travelled on the servo card but I can't find it in the manual. Eric |
| Have you tried adjusting the droop yet. If you check the servo monitor page the droop should read 0 at a stand still. You said you adjusted the gain. Was this at full rapid? 33 sounds like a good number but it should only hit that number on a rapid movement. |
| Problem- Undersize cutting | David Ferguson | Fadal | 3 | 10-21-2009 03:40 PM |
| Help! Plasma cutting undersize on X axis | Normsthename | CNC Plasma and Waterjet Machines | 9 | 10-15-2009 04:51 PM |
| Undersize Parts | 44-henry | Tormach PCNC | 5 | 05-20-2009 09:03 PM |
| Tornado 80 alarms out undersize bar | michael88 | Colchester Tornado lathes | 2 | 08-23-2008 02:33 PM |
| Undersize Threaded Holes After Heat Treat | Newby2 | General Metalwork Discussion | 22 | 01-01-2007 03:43 PM |
