Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-15-2010, 06:06 PM
gneal is on a distinguished road
Mazatrol/EIA fixture offsets
Have multiple Mazaks with M-32 controller with only 6 fixture offsets in EIA(G54-G59). Is there any way to get more? Is it possible to have an EIA program and call up a Mazatrol sub and just have a fixture offset in the sub?? Any help will be greatly appriciated. I have been on Mazaks for the past few years using both G-code and some Mazatrol and I cannot figure this out. AAAARRRGGGHH.
Old 01-15-2010, 06:22 PM
CNCRim's Avatar
I never run Mazak mill but check your parameter manual, and it's doesn't hurt try turn it on, normally it is optional g54.1 ...... blah blah up to g54.9 and g55.1 .... blah blah up to g59.9. Other thing you can try is G52 once you know how to twist it, you can have unlimit virtual offset.
Old 01-16-2010, 06:00 PM
sakis is on a distinguished road
G10G90G54X-220.214Y-50.32Z-120.
G10G90G55X-240.214Y-50.32Z-120.
Program them into an eia sub like above.
Old 01-16-2010, 10:10 PM
MrMazak is on a distinguished road
You can use a Mazatrol main program and have eia subs called in, use the WPC unit to set the program offsets and call subs in for each WPC you need. There is really no limit to WPC's other than the machines memory capacity. As long as no G54,55 etc is called in the eia sub it will use the Mazatrol WPC for it's offset.
Old 01-17-2010, 02:09 AM
CNCRim's Avatar
+1 for Sakis and MrMazak .... so any ideals and way, I guess find one work best for u and stuck with it.
Newbie- Z Fixture offsets gbpacker Fadal 13 09-02-2009 03:41 PM
help posting work fixture offsets instead of G92 rsm169 Mastercam 6 05-21-2009 06:49 PM
fixture offsets beartrax G-Code Programing 1 11-14-2008 06:19 PM
FIXTURE OFFSETS BAD DOG G-Code Programing 20 05-01-2008 06:23 PM
Multiple Fixture Offsets Benji EdgeCam 5 05-02-2007 04:28 PM
