| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hello i have a mazak h 500 and i need an m code function how to turn on the AIR blast thru the spindle,i know i can turn it manual,i want to know if there is an special m function for that Thanx |
| You think there is an parameter to turn that option on? Do you know maybe what is that parameter?(i think that is a little bit to much,) Yes that is an older machine from 1989.Its an m-32 mazatrol control Thank You on your answer |
#10
| All mazaks use air blast in toolchange but the M code was a "standard option" back then. Some models standard... some models option... (just the M codes)... Being an H500 I should've thought about that ... standard on horizontals .... (my earlier remark is an error..)
__________________ It's just a part..... cutter still goes round and round.... |
#11
| I can only get it to work using M119 S0 . I am using this to blow out part for probing bore. I us G1 with a z move feed rate and put in M132 so air thru will come on then use M9 to turn it off, the M119 S0 will set spindle at a angle on the 8800 M119 S0 will set spindle at 0 I hope this helps. |
| NEED POST FOR MITS M-H500 W/MELDAS M3 CONTROL | jzolli76 | Post Processors for MC | 3 | 01-06-2010 09:44 AM |
| Need Help!- POST FOR MITSUBISHI M-H500 W/MELDAS M3 CONTROL | jzolli76 | General CNC (Mill and Lathe) Control Software (NC) | 2 | 01-05-2010 12:46 PM |
| Need Help!- NEED HELP WITH A POST FOR MITS M-H500 W/MELDAS M3 CONTROL | jzolli76 | Mazak, Mitsubishi, Mazatrol | 0 | 01-05-2010 11:48 AM |
| Help with mazak g-code | dgchumley | Mazak, Mitsubishi, Mazatrol | 3 | 05-02-2007 03:32 PM |
| g code mazak | robs_96 | Mazak, Mitsubishi, Mazatrol | 8 | 10-16-2006 02:17 PM |
