Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-08-2010, 02:54 AM
-PC- is on a distinguished road
How to move work rest, IG 400-IV, matrix.
Hello everybody!
How can I move the work rest by automatic in mazatrol?
I can move it with G-codes in a sub program, but how do I program it in mazatrol?
Machine: Mazak Integrex 400-IV
Control: Matrix
Regards
Patrik from sweden
Old 01-08-2010, 08:32 AM
jimiscnc is on a distinguished road
Mazatrol Manual unit
two types on integrex milling manual unit and turning manual unit.
fixed format G code in a mazatrol program. (fixed format = assigned columns for G codes, Axis, F/S words and m code, from left to right)
BEWARE:
A mazatrol manual unit is the only type in mazatrol that DOES NOT RETURN TO INDEX POSITION AT THE END OF THE UNIT. The index position has to be included in the coding at the end of the unit, exactly like a g code program.
At the beginning of the unit, there's a statement that means. "go to turret index position before starting the unit yes/no."
90% jimmy
Old 01-11-2010, 07:24 AM
Can you show wich buttons to push at
My manual says this:
UNo. UNIT TOOL NOM-Ø No. # POS-B
1 MANL PRGGENERAL OUT 10. A"½-square"
SNo. G1 G2 DATA 1 DATA 2... DATA 6 S M/B
1 0 Z -200.
"½-square" is the symbol of the top left of a square.
I couldn't get the spaces correct, sorry for that.
My machine speaks swedish, so the names isn't the same.
But I can't find anything that looks like that...
Wich mounting is normal for the work rest, left or right of the lower turret. Now it's monted to the left side of the turret.
Regards
Patrik
Old 01-14-2010, 05:10 AM
How do I put in the G-codes in mazatrol?
When I tried manual program, it wont work with the work rest, it don't understand Z2 (work rest axis) after G110.
This is what I want to put in mazatrol:
G110Z2; Activate work rest axis
G0Z-200.; Move work rest
G111; Deactivate work rest
But most of all I want to do it in mazatrol
Edit:
Now I have to do 2-3 sub programs for every mazatrol program
It gets messy...
Old 01-14-2010, 10:17 AM
Question
Did you learn Integrex on 640 MT or 640 MT-PRO?
Program formats that are perfectly fine on 640 have to be overhauled when doing the exact same thing on the Matrix.
G110 and G112, for me, anyway, have always been confusing. Especially when Matrix may use different G or M code program words.
I have a cheat sheet comparing Fusion vs. Matrix programming formats for G code.
PM me with your email and I'lll get them to you.
jim
Old 01-15-2010, 01:28 AM
I did learn mazatrol on a Integrex 35 with mazatrol T+, machine from 1998.
The G codes i wrote was from my matrix manual.
Old 01-15-2010, 09:12 AM
a factor
your background may be a factor.
mazatrol from T1 to Fusion T, MT , MPRO and MTPRO was an evolutionary progression. program format and contents were very stable as the mill turn machines and 5 axis machines and opposed spindle machines evolved.
Matrix is a REVOLUTIONARY overhaul of mazatrol, possible the first sweeping overhaul of mazatrol since it's invention in 1979.
So a lot of programming concepts and especially machine specific G and M codes for second spindle, lower turret, throwing commands to the opposite control and machine config related stuff like that got OVERHAULED for more consistency across the three or four or five basic types of control.
M=milling machine up to 5 axis.
T= fixed turret 2 axis lathe up to opposed spindle, Y axis and C axis both lathe spindles.
MT = integrex horizontal-lathe based
MT = E machine vertical integrex - milling based
Migrating to Matrix with your background is painful, but once you get over the learning curve, (and the difficult UNLEARNING needed in your case) you should be in better shape to deal with what ever new technology mazak develops for maybe the next five or ten years, regardless of basic machine type.
-jim
Old 01-20-2010, 06:45 AM
Now I maybe have an answer...
When I program manual program in mazatrol I can't choose lower turret.
I choose MANL PRG and then GENERAL OUT and then TOOL NAME and IDENTIFICATION CODE. After thar I want to choose LOWER TURRET, the half square icon.
But I can't find that in the menu.
Can it have something to do with the missing option nr 59 (lower turret mazatrol)?
I thougt it only was related to lower turret function, maybe it's a necessary option to move the work rest in mazatrol?
Old 01-20-2010, 07:59 AM
My memory is fuzzy, but when you choose upper or lower turret, no character or symbol appears in the program. It's invisible!
I think.
-Jim
Old 01-21-2010, 07:06 AM
It's not invisible, see attached picture from the manual
Name:	nedre revolver.JPG‎
  #11   Ban this user!
Old 07-29-2010, 01:22 AM
John21 is on a distinguished road
Mazak Integrex 400_IV
Tags
matrix, mazak, work rest
TL-2 Steady rest rbest27 Haas Lathes 10 04-17-2008 06:15 AM
Open Steady rest Loelco General Metalwork Discussion 1 02-07-2008 04:29 PM
rest machining camtd BobCad-Cam 4 09-04-2007 06:52 PM
Steady rest auto self centering work trh400 General Metalwork Discussion 1 12-22-2006 12:00 AM
Crazy move, almost work. slp_prlzys General Electronics Discussion 15 04-12-2005 01:47 AM
