Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-05-2010, 10:09 AM
kappullen is on a distinguished road
Boring bar backoff value problem
I am training on a Mazak Nexus-250-II Quick Turn.
I have a threaded (ID) part and need to adjust the threading, and boring tool,
back off so the bars don't crash into the back side of the bore.
I believe the backoff in the software is around .078" which limits the bar size
for a .500-20 thread severely.
Is this a parameter that can be changed easily?
Thanks,
Kap Pullen
Old 01-05-2010, 11:44 AM
extanker59's Avatar
extanker59 is on a distinguished road
On our mazak nexus qt-100 it's in TPC (and parameter) U7
Double check in your Parameters book to make sure yours is the same.
Old 01-05-2010, 11:58 PM
fizzissist's Avatar
fizzissist is on a distinguished road
Funny ya mention that....I just had to reset mine today for a job...a 9/16-18 hole.
'99 SQT250M
U7 is the back-off value....I'm in inches, and the value is in integer units/ .0001
Mine is set at 800 , which translates to .080"
You should REALLY have the manual with all the values. Screwin' around with parameters can get real expensive real quick. Whoever you're training under should know what you're doing, in case you change something they don't know you've changed and .... things get real expensive on a later job.
You should also have access to the parameter, operation, and programming manuals. I think they're horribly written, but you should still have 'em.
..Btw, you can also do MNP and do plain ole G-code for the boring bar if things are just too dicey. My boring bar was way too big, but only option, so I programmed it in G-code, and lowered the threading tools U7 parameter for clearance on it.
Old 01-06-2010, 06:22 AM
extanker59's Avatar
I mentioned parameters in parenthesis but I first said TPC. If you do it in TPC it changes it only for that op. And if you don't like it just cancel TPC with -9999 and you're back to square one. No harm.
What I like to do is make changes in TPC and then run graphics. Watch the tool path. It really does what you changed. If I'm not sure, sometimes I will change it a lot to make sure that it is moving and moving in the direction I expect.
I agree with fizzissist that you should have the book. And that if you change it in Parameters that it could get expensive on a later job. Do it in TPC. Watch your tool path either way you do it! Very powerful tool.
Old 01-06-2010, 03:26 PM
jimiscnc is on a distinguished road
Guys - double check this.
U7 is for Fusion
TC38 is for Matrix.
Same exact concept, just differing parameter address.
-jim
Old 01-06-2010, 03:34 PM
extanker59's Avatar
U7 is for Fusion
TC38 is for Matrix.
-jim
Thanks for clarifying. Yeah, you're right. We have a fusion control and it's U7.
Old 01-13-2010, 06:39 PM
cnc-Mick is on a distinguished road
Definitely TPC for this. Go to program edit, select your bar in or thread in sequence, hit the TPC soft key (menu), and it will list all your clearance dimensions. On the QT20HP I run, clearance in, out, face and back are all set to .080". I would start by changing clearance in to .020 (I've had to use even less before), just make sure your sequence show a highlighted "+" sign, that lets you know TPC is active in that sequence. Good luck, and proceed with caution!
D'Andrea boring head, Solid Carbide boring bars etc. morehelium EBAY ADS 1 08-24-2009 11:19 AM
Need Help!- newbie with boring problem bobo17 Fadal 5 08-11-2009 07:20 PM
giddings and lewis horzontal boring mill problem allmotormatt General CNC (Mill and Lathe) Control Software (NC) 0 02-27-2008 12:46 PM
Z axis Home backoff Stevie Mach Mill 1 12-20-2005 05:28 PM
Which boring bar? kong General Metal Working Machines 25 06-26-2004 05:56 PM
