Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-04-2010, 09:55 PM
the mill kid's Avatar
the mill kid is on a distinguished road
Angry C axis offset
Hey guys been awhile, I am running a Mazak 350 Nexus lathe with a Fusion control running an eia program to do some o.d. milling. I am cutting some slots using the vertical mill spindle 16 times equally spaced then switch to the horizontal mill spindle with a 1/8 dia. lollipop endmill to deburr the face of each slot. Both tools in the program have the same c axis coordinates but the deburring tool is cutting heavy on one side. Without adjusting each c axis location to get it to cut even, can i just put in a c axis offset to control that tool? Any help would be appreciated.
4th axis indexing with offset jeffrey001 Mastercam 8 12-17-2009 01:33 PM
4th Axis Offset PrecisionD Mastercam 9 08-07-2009 07:41 PM
z axis work piece offset The CNC Noob Haas Mills 5 08-04-2009 06:18 PM
Z axis offset changing by itself Rick Kight Cincinnati CNC 2 07-30-2009 07:28 AM
Problem- 6M-B 4th & 5th axis work offset changes R-Bob Fanuc 0 10-08-2008 12:33 PM
