Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-31-2009, 07:43 PM
carbidecraters's Avatar
carbidecraters is on a distinguished road
Adding a steady rest to T32-2 qt15N
So we are going to be turing some rather long bars and need to install a steady rest. How do they integrate into the Mazak we have? Hydraulic correct?
We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
Old 01-01-2010, 11:15 AM
jimiscnc is on a distinguished road
I've seen this done by Mazak and can offer the following:
Mazak engineers 'kits' as defined by an "e-bill". A steady rest retrofit will include a purchased steady - typically LNS or SMW, but also others, a heavy mounting fabrication that usually fixes to the tailstock rails, additional M codes and all the hardware/software, hydraulic hook ups, m code controlled valves for the hydraulics and many many other incidentals.
If your machine is a popular version, Mazak probably has already got this problem bundled up.
The steady rest vendors may also be able to provide some form of kit for you.
Mazak offers a lot of variants for steadys - manual, single roller programmable, and dual roller (turn through) programmable.
This is a substantial under taking for a do it yourselfer. Even a Mazak kit needs a good TECH to put it all together properly!
Good Luck!
-90% jimmy
Does anyone here use an Omnirest steady rest? MadMax General Metal Working Machines 0 12-13-2009 05:34 PM
Need Help!- Okuma Steady rest 641mikeh Want To Buy...Need help! 1 10-07-2009 09:06 AM
puma 250 steady rest bala955 Daewoo/Doosan 0 01-19-2009 08:30 PM
TL-2 Steady rest rbest27 Haas Lathes 10 04-17-2008 06:15 AM
Open Steady rest Loelco General Metalwork Discussion 1 02-07-2008 04:29 PM
