Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-23-2009, 12:15 PM
fbergski is on a distinguished road
Networking Fusion640
Hello,
I need to network my Fusion controls to a central server and have some questions. At my facility we need to store all programs on a designated server folder and pull programs as needed into our Mazaks. Only one program allowed in each machine at all times (current part running on machine).
I believe I can do this my either using the HD I/O or the DNC I/O but not sure how to map the network share folder to the machine.
Any info would be appreciated,
Philip
Old 12-23-2009, 05:16 PM
MrMazak is on a distinguished road
Smile
Most M640 controls are Win95 based and networking is simple. Any IT dept can set up your machines. Share the MC_Backup\Other folder on the machine side and you can drag and drop programs using your network. Use HD-I/O to transfer the prograns to and from the machine main memory. Use CAPS only and use no spaces in the folder name or the machine will not allow you to use it for HD-I/O file transfer. Since Win95 does not support wireless networking you will have to hard wire it. (there are wireless adaptors but I have not seen one works well with a M640) Hope this helps, good luck.
Networking of CNC machines Klaus General CAM Discussion 12 06-22-2011 12:25 PM
networking a2100 jszorady Cincinnati CNC 3 09-18-2009 07:19 AM
Problem- Centroid Networking slucas_clmach Controller & Computer Solutions 0 08-14-2008 07:02 PM
Networking Centurion 7 Jaxmachine Milltronics 6 07-07-2008 11:01 AM
Dnc Networking brtlatjgt Machine Problems, Solutions , Wireless DNC, serial port 4 08-25-2006 11:32 PM
