| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
| We have a '98 SQT 250M w/640T Fusion...without conveyor.... I don't see an 'M' code for the conveyor in my manual,, parts catcher, yes, conveyor no. ????? I would think that the conveyor would be programmable for lights-out production..... Open M-code positions are M20 thru M29, "Robot command" 1 thru 10 ,, That's where I'd check to see how it's wired.....begging the question....who wired it?? Does it show up in the display anywhere? No switch on the control, I'm assuming.. |
| Manual turn on the convey is softkey, i believe it on thirth screen if u just next(arraw key of softkey) u will see it. And for M code to turn on the convey I think m18 is on m17 is off but check your manual.
__________________ The best way to learn is trial error. |
| M16 Orient position 0degrees M17 Orient position 120deg M18 Orient position 240deg M19 Spindle orient This is a 2002 manual, Mazatrol Fusion 640T 3-Axis Specification (With/Without Sub-Spindle and Y-Axis) |
mazak chip conveyors are not that programmable. they are either on or off by switch mostly, also some have low speed and high speed and also reverse. the recent INVERTER TYPE chip conveyors are identified by the plastic orange chain guard on the conveyor. These inverter type allow the use of a timer, found in the plc parameters, that is an interval timer - time on and time off can be adjusted. to retrofit a non-conveyor machine probably involves a lot more than just a plug in. Mazak makes up so called "e-bills', which is basically a documented hardware and software kit for popular factory options. i think mazak gets their conveyors from jorgenson and mayfran and one or two other big conveyor vendors. not much help.. good luck. -jim |
| I don't think Mazak has any M codes assigned to conveyor on/off. It's all in the softkey switches you get when you press the machine menu button - the one with the little wrench. as mentioned above, that will get you to the softkey switches for the conveyor to run or not. jim |
| EMCO PC Turn 50 Lathe | heli_madken | EMCO CNC machines | 8 | 02-02-2012 03:28 PM |
| Need Help!- What lathe to turn 12" O.D.? | Frank_S | Haas Lathes | 11 | 06-20-2009 10:43 PM |
| Problem- reverse on lathe (turn M3 to M4) | Igor_UA | LinuxCNC (formerly EMC2) | 6 | 11-02-2008 01:57 AM |
| Need Help!- LUX-Turn lathe | cad_cam_cnc | General Metal Working Machines | 1 | 10-22-2008 09:27 AM |
| D&D Mini-Turn Lathe? | TurboStew | General Metal Working Machines | 0 | 10-25-2006 11:49 PM |
