Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-11-2009, 02:22 PM
cncamo is on a distinguished road
Question Communications from PC to CNC
I have a Mazak AJV 60/120 with an M-Plus controller. For the past (3) years it has been giving a tape error when drip feeding from the PC, but only if the program is longer than about 10-15 blocks. It will load the entire program into the memory but will not make it through the program when drip feeding.
I have checked all parameters that were set when I had it working and they are all still set the same. I called Mazak and they said it sounded like the QX something, something, something, board. I had a repairman check it out and he replaced the board and $3500.00 later (not counting the board), still no luck. the board was returned to Mitsubishi since it did not seem to be the problem.
Can anyone tell me how to fix this or what to check?
Old 12-12-2009, 09:47 AM
psychomill is on a distinguished road
That card would've been my guess (if all other settings are correct)....
But question: You're drip feeding a program that might be as short as 10-15 blocks???
It's just a part..... cutter still goes round and round....
Old 12-14-2009, 11:32 AM
Correct. For example, if I send just a drilling program with 4-8 locations, it will work fine. Any more locations than that it will only make it so far and stops. It seems like a buffer error????
Need manual for BMC 30/D and ? about communications apylus444 HURCO 3 05-14-2011 11:04 PM
PC to CNC Communications ignisuti General CNC (Mill and Lathe) Control Software (NC) 0 11-06-2009 04:50 PM
I need help with communications peterpan3 Mazak, Mitsubishi, Mazatrol 6 03-24-2009 06:44 AM
Need Help!- 98 HAAS VF-3 communications jeff@rans Controller & Computer Solutions 8 10-08-2008 01:11 PM
PDA Communications rfmerrill General Metalwork Discussion 0 02-09-2005 07:03 PM
