Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-06-2009, 05:09 PM
mbi mbi is offline
mbi is on a distinguished road
drip feeding an m2 control
I can't figure out how to drip feed a m2 control? I know on the m32, mplus, and fusion 640 all you need to do is use the tape mode. I can't find the tape mode on the m2. Can I drip feed in tape mode or do I need the DNC opition?
Old 12-08-2009, 01:09 PM
jimiscnc is on a distinguished road
Doggonnit! No replies yet.
I also have an M2 with the so called DNC option. I would like to drip feed into the buffer and need as much info as you all have out there to figure it out!
thanks
jim
Old 12-08-2009, 02:24 PM
Rokkin is on a distinguished road
DNC on a standard Mitsubishi M2 control requires a certain s/w version.
I believe it's 7005. If you don't have it, Mits can re-write you FX04 PCB. You will also need new chips for your FX25 pcb.
If you have the option already installed, for the DNC function to work you need to set "TAPE (RS-232) on the last page of user parameters. You must also reset "PTR ALLOW" in the machine parameters.
Old 12-08-2009, 04:24 PM
mbi mbi is offline
Thanks Rokkin, I will check it out.
Drip Feeding widgitmaster Polls 26 01-28-2011 02:02 PM
Drip Feeding capital General CNC (Mill and Lathe) Control Software (NC) 0 04-08-2009 06:19 AM
Drip Feeding Andre' B General CAM Discussion 3 10-27-2008 12:40 PM
drip feeding vtc-41 scottn Mazak, Mitsubishi, Mazatrol 1 11-08-2007 06:52 AM
drip feeding problem yoya Machine Problems, Solutions , Wireless DNC, serial port 31 07-07-2006 12:33 PM
