| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
| What is the exact alarm you are getting? Is it a windows alarm or are you getting this on the alarm diagnosis screen? Did you replace the battery in the NC or the MR-J2? What do you mean you cleared the MR-J2? Did you reload the parameters to the MR-J2? |
| "Communication error between personal computer and the servo amplifier, Check Connection." Then I closed this one and another window came up, "SPECIFICATION CHECK FOR CONNECTED MR-J2-CT" It can not distinguish between the Rotary Axis and the Linear Axis, For communication error. Wich do you want to connect the Rotary Axis or the Linear Axis?. |
| Error 21 is a software alarm and it may be because one or more of your MR-J2s lost its mind. I'd reload the MR-J2 parameters like onthebumper mentioned. What machine is this? and how did this all originally start?
__________________ It's just a part..... cutter still goes round and round.... |
| Also check the MR-J2 drives. They should be flashing some alarm on them. If they are blank or have a solid display when the NC control is on then one of the drives is bad or you have a communication problem to the drives. |
The problem was in one of the MR-J2 drives, Someone changed a switch that is on the front of the drive, The LED screen in the front of the drive has to digitals numbers and on the right side has a switch with numbers (0 to 10) and letters (A to F), I have four drives and none of the drives can't have the same number, so two drives were using the same number(2), I have to go to the MR-J2 and check the axis settings and give them the right number. I WANT TO GIVE THANKS TO EVERY PERSON THAT TRY TO HELP ME,THANKS ALOT |
| Fanuc 6T system error | salmve | Fanuc | 30 | 03-08-2012 02:22 AM |
| Need Help!- system error 902 | woonsteel | Fanuc | 2 | 08-06-2009 03:37 PM |
| 6M System Error | Sailor | Fanuc | 7 | 06-01-2007 05:56 AM |
| ez-trak system error | Tru Cut Machine | Bridgeport and Hardinge Mills | 2 | 08-27-2006 09:33 PM |
| 904 system error on 6M | kstocklin | Fanuc | 9 | 01-30-2006 06:57 PM |
